My review for the Sony A7 II and Nauticam NA-A7II housing is now ready for download at UwP = Your free Underwater Photography Magazine | Home page. This is a Free PDF download for the next two months.
Hi Phil
Great review in UWPMag... Thanks. It is helpful.
Indeed, being a long time Minolta users, now playing Sony, I am currently shooting UW with a Sony Alpha 850 DSLR (Full Frame) in a BS-Kinetics housing...
I am considering moving to mirrorless and the Sony A7 Rii looks so attarctive and so expensive...
Anyway, I am ready to jump...
However, 3 questions to you
- what is your experience with the 28mm and the 16mm FE converter ?
- have used any A-mount lens with the LA-EA3 adaptor in the housing
- do you have any feedback using old Nikonos lens (I still gave, dust free, the fabulous UW Nikor 15 mm...)
Thanks
Eric
Hi Eric,
Thank you for your acknowledgment and good to hear the article was helpful.
I have been shooting underwater since 1968 so I have worked my way through many systems always  taking a system approach to what I invest in. Also being Senior Reviewer for uwpmag.com has given me a chance to use lots of equipment that was not my own.
This is my first move into Sony full frame cameras and I am moving quite slowely regarding lens purchases for this system. To answer your questions first I have not yet used the 28mm above or below water so have no experience with that lens. I moved from fifteen years as a Nikonos RS user to Olympus E-1 then all the way through to EM-1 before moving to Sony. I have not at this time used any of the lens adapters and have looked only at FE lenses for my current system.
I have used the Nauticam housings and adapter for Nikonos lenses with NEX cameras but not on FF. Results are as you would expect from a lens designed for film and would not exceed or in some cases reach the results you would get from the 16-35 zoom and Nauticam 180mm optical glass dome.
One of the things I really like about the Nauticam housing is that it supports both A7 II and A7R II (and fingers crossed A7S II). This is a big upside for me as I always travel with a backup camera for topside travel shots and in the event of the dreaded "F" word. This allows me to use an A7 II as backup and the A7R II as primary UW camera.
Again I am very happy with the results from the 90mm macro and the 16-35 and I expect my next step will be a fisheye or fisheye zoom.
    • Problem Description – Sony ZV-E10 II A few weeks ago, I purchased my Sony ZV-E10 II camera from Digital Photo Supply. The unit is updated to the latest available firmware and is showing an abnormal behavior in the continuous autofocus system (AF-C), which can be consistently reproduced under different conditions and with various native Sony lenses. Observed Symptoms The parameters for focus transition speed (AF Transition Speed) and subject shift sensitivity (AF Subject Shift Sensitivity) do not remain stable. When the camera encounters a point or surface with low texture or contrast and takes time to focus, instead of maintaining smooth “focus breathing” according to the settings, it makes a sudden jump to focus. From that moment, autofocus behaves as if the speed were set to the highest value, completely ignoring the configured settings. After a few seconds, or when reframing, the system resumes normal operation. This phenomenon occurs even with Active Stabilization, Face/Eye AF, and Touch Tracking turned off. Testing Methodology Tests were conducted under various lighting conditions, both high-contrast and flat light. Different subjects were positioned at varying depth distances but laterally aligned (scenarios with partially overlapping elements). Medium and low focus transition speeds and medium or low subject sensitivity settings were used—these are the cinematic parameters I normally work with. All tests were performed exclusively with native Sony lenses, varying light and contrast levels to check behavioral consistency. Under these conditions, the camera consistently showed instances where, when using Spot Focus (S/M/L), it would momentarily lose focus and, upon regaining it, start focusing instantly on any new subject as the camera moved—completely ignoring the configured transition speeds. Control Camera Used A Sony ZV-E10 (Mark I) was used as a reference with identical lenses, settings, subjects, and lighting conditions. It passed all tests successfully without reproducing the issue. Impact on Professional Use This malfunction is catastrophic for my professional video work, where precise and fluid focus transitions are critical. When the system ignores transition speed and sensitivity settings, the footage becomes unusable, directly affecting visual continuity and cinematic quality. If this behavior cannot be corrected, the camera is unsuitable for professional video use, as it compromises focus system stability and predictability.
    • What flash are you using? A Sony one?
