NEX-7 Viewfinder Magnification „35mm equivalent“ and „nominal“/What is the difference?
Hi gents.
In the specifications for my Sony NEX-7 are two statements with regard to the viewfinder magnification:
Viewfinder Magnification (35mm equivalent):
0.73x
Viewfinder Magnification (nominal/claimed):
1.09x
Could somebody tell me why there are two data and what is the difference between „35mm equivalent“ and „nominal/claimed“? I know that the crop factor is 1.5 and if you multiply it with 0.73 you get 1.09. But how useful is this info? I mean it is the viewfinder, not the lens.
If I wanna do some math, do I have to go with the factor 0.73 or 1.09?
Any input is highly appreciated.
Thank’s and stay healthy.
GMichel
