Hello. I just got Sony Alpha S 3 and came home from trip. All my footage is in 60fps so i could make some smooth slow motion in post production.
Problem is that all my footage is choppy when is slow it down by 50%, when i played video frame by frame, every second frame is just missing, thats why my footage when its slowed down, looks like 15fps. Theres is no problem with gopro at 60fps.
I am using Premiere pro latest version. Is that problem with camera or Premiere pro? Maybe someone has some solution
