TTL issues with a Nissin Air 1 system
Hi all!
I hope someone can help me with a TTL issue I'm having.
Kit:
Sony a9
Nissin Air 1 commander
Nissin i60 flash
Issue:
Can't fire the flash in TTL mode. The flashes are definitely paired (works with test flash) and the flash will work wirelessly on manual mode but will not fire on TTL.
I've tried putting the camera on WL mode in the menu system and also selecting the mechanical shutter.
Anyone got any ideas?
Many thanks,
Neil
