Wow! Stunning clarity.
Can you give us an indication as to whether you have cropped the pics? Or what lenses you've used.
From the advertising, they say you can blow the photo up to 6ft x 4ft and count the fibres on fur! Alternatively use very heavy cropping to get good photos from a distance that you can't see in the lens (like facial expressions of a sports person on the other side of the pitch.
This is the hawk full-size, all photos from 200-600. The hawk was shot with the 1.4tc
Sadly, my α1 is already headed off to the repair shop. When I first got the camera I noticed a constant humming sound. I assumed it was a cooling fan but it does not have one. The battery was also draining very fast.
I contact Sony this morning and they told me to send it in for repair as it’s not supposed to do this. The sound is clearly audible in video record as well.
Edited by LiveShots
