Hi guys, hope you're all doing well!
I have had an issue with my a7iii the last weeks, when photographing purple spots appear on the final picture (see image), this happens with all of my
lenses so it has to be a problem with the camera... I have cleaned my sensor but the problem remains! Does anyone have a sollution to this?
Thanks for reading, stay safe :)
    • I have my A7C set to back button focus (using AF-ON button) and half press disabled. I am using "Tracking Expand Flexible Spot" focus area which I like for street. The problem I am having is after, the square focus block has tracked the subject, which can sometimes be to the edge of the frame and if I release the back button it stays there and from then on I can't move the square back to the centre. Any attempt to use left, right, up, down on the joystick just takes me into the function for the joystick. Occassionally it plays ball and moves for me, but I can't fathom out why, but 80% of the time it stays where I don't want it to be. I am assuming I am doing something wrong, but don't know what. Is there any way (in order of preference) to: Make the joystick control the focus square when I want it to? Make the focus square default to the centre of the screen? Disable the functions on the joystick so it only controls the focus square? Any help much appreciated
