  • 2 months later...
I had this trouble when I got my new A7iii.  In Camera Menu 1,  1/14, APC-C/Super 35mm, set Shooting to Auto and Manual to Off. The camera will then detect whether you are using a full frame or an APS-C lens and set the sensor accordingly. This works for me with Sony, Sigma and Tamron lenses.
