Can't record audio with either camera or either mic
I shot three talking heads this morning with my A7III (2.5 years old). I couldn't get either of my microphones to work. That's never happened before. One is a Rode VideoMic Pro (my backup) and my go to boom mic is a Sennheiser MKE600.  Regardless of what was plugged in, or which camera I was using (I also tried my A58), nothing recorded but each camera's on-board microphone. The resulting audio is really bad. I tried multiple connections, cords and batteries and it still wouldn't record audio. I even reset my A7III and it made no difference. I'm willing to go back and rerecord but I want to see if anyone can make these audio files acceptable. Even though we picked the room we shot in because it was the quietest, the ambient noise on these recordings is awful. Even if I go back, what camera am I going to use? Let me know if you can help. I'll send you a snippet if you think there's hope.
David
