Dear friends,
I am confused about powerbanks.
Is it just to charge the battery in the camera or you can record video as well while a powerbank is connected to the camera.
Many people suggest the Anker Powercore 20100 but they say thats for charge. Is this for recording as well?
Or does anyone can suggest a powerbank that works with sony a7iii?
thanks
George
  • 3 months later...
    • I'm interested in creating videos with my camera. I'd like to automate the movement of the camera (pan left/right, zoom in/out, turn left/right, etc.) I believe I need a motorized camera tripod. Can you recommend a motorised camera tripod?
    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
