Hi. I own Sony A7RII. Recently I discovered that record button is not working. The button is fine, nothing stuck over there. I reset the camera setting and pull out the lens.
Still the rec button is not functional?
Am I missing anything?
  • 5 months later...
  • 1 year later...
  • 11 months later...
I had the same issue, I couldn't resolve it but I found a work around that's even better. You can set up custom buttons in the settings. I changed C1 into MOVIE. So when you press the C1 button it starts image capture. I like it better as it easier than the fiddly small actual record butto.
