Alpha 7rIV - Manual mode, dim viewfinder
Hobie
Unteathered in the studio with pc cord flash sync.  Manual mode, fstop set determined by strobe light meter .... say f16 @ 1/160 iso 200.  Viewfinder and live view is too dark to even see image.  ( screen adjust brightness  based on available light)  I have to switch to aperture priority to compose shot, then switch back to manual to take photo.   Any ideas?  Many thanks.
