Hi guys, I'm new to this forum and I hope not to break any rules.
I'm writing here because I got a strange problem with my Sony A7S II. At this link you can see what I'm talking about
What do you think it might be? How can I solve this?
Thank you so much,
Francesco.
This being your first post I'm tempted to call this a "fake" problem, probably caused by a slight difference between the recording frame rate and the play back frame rate. Nothing to worry about.
Note, that the space to the right and left of the screen shows the same kind of flickr at the same rate.
Edited by Chrissie
Isn't it amazing, how easily some so-called problems get solved?
Note that this was a fabricated problem, which the poster couldn't see with his naked eye. It just got generated by recording it and playing back the result to us.
I really hate those spammers.
  • 1 year later...
