LOW LIGHT "PURPLE COLOURING"
Hi
I've just changed over to Sony from Nikon
I'm using 2 x Sony A7iii
Zeiss 25mm f2
Zeiss 85mm f1.8
The picture was taken using the 25mm
It was on a tripod
Timer
Iso 100
F5.6
00.30 second
The question,  where is the purple light coming from, it's on all the low light pictures I took and there wasn't any purple lighting in the area, is it a Sony sensor issue or a lens issue, not too impressed at the moment
Thanks in advanced for your comments
John
Edited by jarjar211
Can you delete this topic as I placed 2 of the same on the site
Since this was a low-light situation (exposure time 30 seconds), my guess is, that the AWB did not find a proper reference point for "whiteness".
If you've shot in raw format, you could correct this during postprocessing.
To avoid this in future shots, you may want to experiment with manual white balance settings.
Note the 2nd bullet point in the "Note" section of the above linked section of the user guide:
Quote
  • If you use a mercury lamp or a sodium lamp as a light source, the accurate white balance will not be obtained because of the characteristics of the light. It is recommended to shoot images using a flash or select [Custom Setup].
It looks like the street light (which cast your shadow on the sidewalk) may have been one of those mercury or sodium lamps.
