Nikon Long Lenses on a a7
Neil
Has anyone ever tried say a Nikon 300mm f2.8 or longer on a a7?
I wouldn't mind given it a got but reluctant to spend 300 dollars on an adapter just to give it a try..........it would be for shoot wildlife
Any advice tips would be much appreciated
Later
Neil
Later
Neil
Can't talk for Nikon but I use 300 and 400mm Canon FD lenses on my A7
(PS: Sorry, but the SW of this forum softens everything...)
What adapter goes for $300 ?
I'm using the MetaBones ...
for only $100, top quality.
Before that one I was using
a borrowed "Fotasy", a $25
item, with clunky latching
mechanism, aluminum rear
flange, kinda tight front
[chrome/brass] flange, but
it was built planar true to
the sensor plane [critical
focus test, fast WA] and is
correct for infinity focus
[fast WA test again].
The Fotasy is apparently a
step up from even cheaper
stuff that is often reported
to be out-of-plane to the
sensor etc etc. Thus it's a
perfectly good adapter for
getting your feet wet.
The MetaBones is correctly
aligned, excellent chrome/
brass for both flanges, a
really good latch, and the
tripod fitting by itself can
easily justify the $75 over
the Fotasy, which has none.
Interested to know what, if
any, miracle is included in
a $300 adapter. I use nothing
but old F-mount lenses on my
A7M2, so I'm not joking. If I'd
get a serious advantage, for
$300, I'd consider doing it.
Hi Neil and welcome too, i used a nikon film era 70-210mm on a7m2 with no problems with a cheap ebay fotodiox 16$ adapter and got results, however, i stepped up to a metabones which Golem rightly implied is better built with finer tolerances and better machining and also has the tripod mount, i think you will find apart from possible physical handling disparities long zooms will work great on a7x with any reasonable adapter and even better with more finely crafted adapters such as the metabones etc..
I did notice some fringing at f4 on the nikon lens, but not abhorrent nor aesthetically abominable, certainly not hideous.
  • 4 weeks later...
The metabones speed booster is around that figure isn't it?
Adds a stop (I think - I've not used one as I prefer Novoflex)
so there is some advantage.
Tim
No. There's no advantage. When you put a SpeedBooster
on a FF lens, you do gain a stop, but you render the lens
into APS-C territory as to format coverage. The purpose
of such devices is to restore the original field of view when
using a FF lens on an APS-C body/sensor. They could be
functionally described as being the reverse devices as the
tele-extenders [shrink image size but gain lens speed].
