Hi
I would like to use a sony full frame camera to take photos triggered by a motion sensor for extended periods of time.
The system im making would require the camera to be plugged in power, accept a motion sensor, and most importantly, I would like to be able to change the image setting (aperture, ISO, shutter speed etc) via the Raspberry Pie. Im going to setup the system pretty remote, and want to be able to change settings, download pictures etc without visiting the site.
Do you know if this is possible with some of the full frame Sony cameras?
Thanks!
I can fully relate to why one would want to make his own solution, although there may already be one or more  solutions commercially available.
That said, what you intend to achieve sounds pretty much like "tethered" shooting, for which there exist several solutions, or maybe combinations thereof.
For Sony FF cameras, there is the Capture One Pro software which supports wire-bound tethered shooting, including aperture, ISO, shutter speed control, live view and image data transfer from the camera to the remote computer. I do not know, if a motion sensor can be applied to the camera "on top", as the USB connector of the camera will already be occupied by the tethering cable.
If you want to go for wireless tethering, take a look at Camfi Pro, which also supports aperture, ISO, shutter speed control, live view and image data transfer from the camera to the remote computer. Note, that no focus control whatsoever is supported by Camfi Pro for Sony. (This is not obvious from their advertising, which I only found out the expensive way). The Camfi Pro device is connected to the USB port of the camera, and I have no idea if and how a motion sensor could be added on top, if you intend to try that.
Hi.
Thanks for your good input.
The system will have to run well without me present, so the core function will be to be able to take photos with an activation signal. The adjustment will only be something I do once in a while.
Someone has made a simple system that shows this function:
https://www.youtube.com/watch?v=u2O082hDafs
As you can see, they plug the USB cable into the raspberry pie (which also has a motion sensor), which activates the trigger. However, the raspberry is a linux based computer, so this limits the use of professional applications as these typically run on mac or windows.
The Capture One Pro looks very good, though...
Do I only need to connect the one USB cable (both charging and camera control)?
    • Problem Description – Sony ZV-E10 II A few weeks ago, I purchased my Sony ZV-E10 II camera from Digital Photo Supply. The unit is updated to the latest available firmware and is showing an abnormal behavior in the continuous autofocus system (AF-C), which can be consistently reproduced under different conditions and with various native Sony lenses. Observed Symptoms The parameters for focus transition speed (AF Transition Speed) and subject shift sensitivity (AF Subject Shift Sensitivity) do not remain stable. When the camera encounters a point or surface with low texture or contrast and takes time to focus, instead of maintaining smooth “focus breathing” according to the settings, it makes a sudden jump to focus. From that moment, autofocus behaves as if the speed were set to the highest value, completely ignoring the configured settings. After a few seconds, or when reframing, the system resumes normal operation. This phenomenon occurs even with Active Stabilization, Face/Eye AF, and Touch Tracking turned off. Testing Methodology Tests were conducted under various lighting conditions, both high-contrast and flat light. Different subjects were positioned at varying depth distances but laterally aligned (scenarios with partially overlapping elements). Medium and low focus transition speeds and medium or low subject sensitivity settings were used—these are the cinematic parameters I normally work with. All tests were performed exclusively with native Sony lenses, varying light and contrast levels to check behavioral consistency. Under these conditions, the camera consistently showed instances where, when using Spot Focus (S/M/L), it would momentarily lose focus and, upon regaining it, start focusing instantly on any new subject as the camera moved—completely ignoring the configured transition speeds. Control Camera Used A Sony ZV-E10 (Mark I) was used as a reference with identical lenses, settings, subjects, and lighting conditions. It passed all tests successfully without reproducing the issue. Impact on Professional Use This malfunction is catastrophic for my professional video work, where precise and fluid focus transitions are critical. When the system ignores transition speed and sensitivity settings, the footage becomes unusable, directly affecting visual continuity and cinematic quality. If this behavior cannot be corrected, the camera is unsuitable for professional video use, as it compromises focus system stability and predictability.
