So I made it into the San Diego County Fair with my one my photos, and I need help with printing for the actual competition. The printing guidelines are as follows:
https://sdfair.com/downloads/2018/exhibits/entry/Photo-Print-Specs.pdf
The guidelines I feel like are a bit vague, so I just order my print on Zno with this mounting:
https://www.zno.com/mounted-print.html
Do you think this meets the requirements?
