With the Sony a9 I am not able to copy images from slot one to 2 or vice-versa using Sony SDXC II 64 gbs cards.  Both were formatted before use.  Tried several times and it may copy about 90 images of the more than 1200 in the card.  Any solutions?
Got it, thanks... on mine it copies the images from the currently selected date or folder. So it won’t copy all images unless they are are all in the same folder or were taken on the same date.
I think I you were viewing by date then it will only copy that date, try switching to folder view before accessing the copy function and see if that works.
