Probably A7r with IBIS and minor improvements- quieter shutter, for example .
I'd guess s cond card slot and more robust battery not happening now, maybe never unless Sony increases body size and weight.
I just wish Sonybwouldvannounce the unitbso we could assess it
Well it certainly makes sense to beta test a small batch.
As for things Sony does not currently see fit to alter, such
as the battery or single card slot, they don't need anyone's
opinion if they are not considering any changes. A poll of
user reactions is only useful if change is being considered.
Beta testing puts potential problems into the hands of real
users. Real users do things, combine various settings and
work habits, that might never occur to the designers who
operate pretty much in a bubble.
For instance, there's a FM glitch in the A6000 that bothers
me. It combines 3 things in a manner that clearly wouldn't
ever be discovered by the designers. Very nice of Sony to
have added the memory recall [essentially 3 user custom
configs] to the A6000. But if you use back button focus as
your personal normal mode, you will hafta reactivate that,
via the menus, anytime you insert a battery with the mode
dial set to MR.
IOW, changing the battery defeats the back button focus
setting. Yes the back button DOES still focus, but also the
shutter button focusing re-engages, which acoarst defeats
the whole purpose of back button focusing }:-(
Things equal to the same are the same ... for example:
Solution to problem =
dial away from MR to insert battery =
waaaaay stoooopid procedure =
Solution to problem ..... [ad nauseam]
I'm no engineer, but IMNSHO this is a FM glitch.
Back button focus is a common preference.
Changing batteries is a common chore.
Therefore: It's likely that if 20 users beta tested the A6000,
almost half of them woulda checked out the back button
focus [cuz it's so useful] and ALL of those woulda changed
batteries [cuz it's sooo necessary] and AT LEAST one of
those testers also woulda been checking out the MR mode
[cuz it's so cool]. That user woulda then started wondering
why the back button focus sometimes disappears and, as
a beta participant, been obliged to report that to Sony.
So kudos to Sony for what appears to be a beta test run.
