My first picture here  :)
A picture of my iPhone on my desk, shoot with my 85 Batis @ 2.8 1/320 using three Lumopro LP180r flashes triggered by Phoenix Odin II (HSS) for Sony. Screenshot of iOS-home screen is added in post.
