Hi,
thanks for the great forum.
I'm about to place my order and I want to be sure about some things that I think someone here can have the answer:
1. I'm planning to connect A7 (not sure which model yet) -> Capture card (probably Black Magic recorder) -> OBS to stream. Is this right?
2. Does the signal from the camera to the capture card is with full quality?
3. Can I power the camera using AC adapter for much time I need?
4. How can I mount Canon lens to it? Do I need an adapter and if yes which type do you suggest?
Thanks in advanced,
Gorast
Hi.
1) don't know it works from capture card to OBS, but i think this has nothing to do with the camera.
2) for full quality video u must use slog (and you need to post process that) and maybe u need SDI over HDMI for the last bit of dynamic range. I don't know your capture card has SDI or u need a HDMI -> SDI box.
3) with AC adapter it works, but not sure with USB.
4) u need an adapter, Metabones for example.
Cinema5D has some in-depth reviews about videographie.
