Since I got an LA-EA3 I'm all buzzed about auto-iris.
It's like it's the early 1960s and I just got a then-new
camera ! Auto-iris ... Whoooo-hoot ! I still use my old
Nikkors on a Metabones non-coupled adapter where
I don't need auto-iris, but the automatic is such a kick.
Here's the hardware:
Here's a shot at the near limit. Unfortunately, the
tiny file size allowed here is especially destructive
to this shot ... so I added a crop section at maybe
barely enuf improved rezo for getting the "feel" of
the subject and lighting.
Crop Section:
The whole view  ... you'll just hafta  imagine the proper
texture. If you view this closely, it will fall apart before
you ever see the texture thaz shown in the crop above :-(
Sooo ... why did I even bother to post a pic thaz almost
toadally fuggdup by the file size limit ? Well, cuz it's the
type of shot that overcomes my reluctance to use zoom
lenses. It's window light and constantly moving. Trying
to keep the shot together while chasing it with a tripod
is just too frustrating.
Here are examples of why I unmothballed this lens.
This scene is about 2 miles from home, but I hafta
do almost the same thing for hire, in Manhattan, so
this is a great dry run. Same horrible lighting, too !
IIRC this is about ISO 8000 f/3.5 @1/60.
One unanticipated, intangible, very important, not
to be ignored discovery of this dry run concerns
the ergonomics of this lens. It feels comfortable
and well balanced, smooth and easy to operate ...
BUT ! Being an AF lens that I'm using only in MF,
the focus ring has so little resistance that about 70
to 80% of the test shots were focused somewhat
beyond the intended subject :-( It seems no matter
how carefully I focus, as I remove my finger from
the focus ring I tend to shift the ring just a tiny bit,
toward more distant focus. Important thing to have
become aware of, since I'm so accustomed to my
trustworthy well-behaved ancient Nikkors !
So here's a couple examples of how looks when
I don't fuggup the focus:
It's not fully wide open, but it still helps direct the
eye to the chosen player even tho they are not at
grossly different distances. And the background is
still providing recognizable context without being
a major distraction. I love that. Now all I gotta do
is practice letting go of the focus ring without my
nudging it toward more distant focus ....
