Hi everyone.
I'm seeking for help for an issue with my a65 camera.
I bought it second hand,it has always worked fine for over 3 years,then yesterday I came back from a few days of holiday and upon trying the camera again I noticed that when switching it on, the frame menu on the screen only appears for a fraction of a second,then it disappears and the camera is left with very little functions.
I can only shoot with manual focus  and can't change settings, can't access the system menu, can't access the dial menu,all the buttons seem to be frozen.
A further detail is that I seemed to have some issue with my holiday based camera, an a390 that didn't seem to read 3 out of 4 sd cards I tried to use,it only worked with a 32 extreme pro.
Can this be a virus that can be transferred through SD cards?
Or any other ideas?
I can share a video of the screen if necessary.
Thanks.
1 hour ago, GianniC. said:
Or any other ideas?
Welcome here.
Don‘t swap SD cards between cameras without formatting. And keep in mind that your camera is quite old so cards with bigger capacities might not work.
Concerning the a69 - did the camera possiböy get wet?
Yes, there was no "reset" option though,in the system it's called "initialize"
I tried several times,in order to do that I had to repeatedly press the menu button right after turning in the camera so I could get that fraction of a second in which the menu appears on the screen,if I miss it I'm not able to access it.
Edited by GianniC.
