I cannot get this lens to hold manual focus.  The focus on the lens is in manual.  The camera setting is in manual.  I can focus the lens and first image is tack sharp.  If I either turn camera off, or the energy saver kicks in at 1 minute, I lose focus.  I understand there is no focus hold on lens.  What can I do to keep the focus on this lens from shifting.   At first I thought it was a defective lens and traded back in for a new one.  The same behavior occurs.  Recently my first image was taken at 4:46 a.m.; my next image w/out touching focus, but turning off camera was taken at 5:01 and is totally soft.   The prior new lens shifted focus working with an intervalometer.  Every time I stopped camera to check focus, it was out.  Any clues or workaround for this behavior would really be appreciated.  Auto focus works just fine.
2 hours ago, Pieter said:
think this behaviour is normal for most - if not all - focus-by-wire lenses: the focus position is reset when the camera powers off.
Any way that turn this feature off or have it reset to existing focus?   Trying to use lens with my tracker for star photography.
