I am trying to understand what get saved in the the memory settings? It appears there are two main ones with then sub save options as well? Has anyone any idea what is saved by default?
I Am, for example, trying to save a setting for studio work so manual, no prefocus light, no live view and so on but that seems to be impossible . The memory saves seem not to be full camera settings just very limited ones or am I missing something?
I'm with you. I dont understand how you set the memory, and i dont see it in the book. Like, it would be nice if one memory could be for image stabalization off, manual focus, 100 iso, etc for when i use a tripod... and then another for silent shutter, 1000 iso, image stabalization on auto, AF wide for when im doing street photography.
Anyone have a link to good write up on this or can explain?
Thanks
I too gave up on experimenting with
the memory thingies. I really like the
idea. I use all memory channels on
my Canon so when I saw what looks
to be 8 channels on A7M2 I thought
that looked great.
Maybe someone who's figgered it all
out will post the magic info here ?
Sony's menu system is utterly confusing - to the point of being downright bad. I have A7R2 and 5D3 - the latter has built-in help for the advanced functions. You just press the "Info" button to get an detailed description of what the different options do. It is all very logical and easy to understand.
But Sony want me to go online and read some "Help manual". Apperantly they forgot to include that in box....
The memory system is quite simple. I don't use the sub-memories as I find two is enough for me.
Just set the camera exactly the way you want to shoot, including your preferred "starting point" for aperture, etc. Then save that to one of the memories. Then change all the camera settings to the second style you prefer. Then save that to the second memory.
I have M1 set to a very manual setup, with AF-S, 100 ISO, Aperture, Spot focus, Etc. I think of it as my "careful quality" setting.
I have M2 to a very automatic setting, with AF-C, tracking, Program, Auto ISO, etc. I think of it as my "grab what's happening quickly" setting.
The other useful thing about the Memory is, when you've been messing around with settings, one flick of the mode dial and you are back to a "known state".
Works fine.
Regards
Peter
http://www.peterwalker.com
Sorry but I have to disagree, it does not work fine, you cannot memorise all the settings that you would use for example studio work where the live view and preview wants to be off, all that get remembered are the basic parameters that are shown on the memory screen, and worse still the sub memories are stored on the sd card not the camera , take the sd card out and the sub menu display  nothing stored and if you change cards you loose the submenus you have stored, realy not thought out very well by Sony hopefully an upgrade at some point might fix it.
The memory settings only save what is in the first 'tab' of the menu (the camera one), not the cog or other menus.
That covers most things you get to from the Fn button, but not (for example) slient shooting as that's in the cog menu tab.
-Alastair
Do the A-mount cameras have a better implementation?
Edit, no apparently not. If I were a pro I would probably stick with my DSLR ....
Are you talking about the 1 and 2 modes on the mode dial?
I have mode 1 set to shooting Raw and mode 2 for shooting video. Thats all I need. I have not attempted to set M1, M2 etc and maybe thats why my memory recall slection in the menu is always greyed out.
Well this is not good news but at least it's news. I'll
now cease wondering how to use them, and ignore
them. I'm very spoiled. My Canon SLR remembers
everything .... except to buy my wife a birthday gift.
Now, about them Sony "Picture Profiles" .... ? My
camera has several editable profiles, and I don't
know if they are default settings, or edited by the
first owner. I've just begun messing with them.
I probably changed them from default!
Let me qualify my comment then: it works fine for me. I'm OK with just two memory settings that are accessible from the mode dial. Don't need 8 memory settings. Probably couldn't remember what I'd saved in the 8 slots anyway. And the savable options cover everything I need to switch on the fly when shooting.
But then I'm not one to spend time playing with camera settings. I'm old school: Set, Forget, Focus attention on the image then Shoot.
  • 1 year later...
As was touched on earlier in the thread, it's worth emphasizing
that even if you find the memory thingys deficient or useless, be
glad that they are there. They do serve one great purpose even
if you have no other use for them. We see posts now and then
asking why some feature doesn't work or is greyed out and the
the replies to such an OP usually include the suggestion that the
user may have changed stuff without realizing it. If it were not for
the memory channels, you'd hafta "Initialize" the whole camera
to be rid of accidental changes that you maybe made but maybe
did not make. Initializing undoes ALL your personalizing of your
camera ... returns everything to Factory Default. Using one of the
memory channels can test whether you indeed have made some
sorta change that you're unaware of. If using the memory channel
unblocks the mystery problem, then you'll know your blockage is
due to some setting you have accidentally made. You'll still hafta
figger out WHAT change you made, but at least you know where
you stand ... you know that the camera isn't malfunctioning.
