My first reaction was “is this a reference to the mechanical shutter noise?” - after all, the shutter is close to the sensor…
But if referring to the built in microphone, I assume this must be video, and I don’t know if video on the A7IV or A7RII (the title says A7IV, but the tag says A7RII?) uses the mechanical shutter - does it? Or is video always electronic shutter?
@cutman - what is the sound you are hearing?
Have you considered getting an external microphone? - lots of people use Rode microphones, for example.
Video (at least in modern cameras) always uses the electronic shutter. I don't know of any camera that can do 25-30 fps with the mechanical shutter. Let alone the noise is would make 🙉
There is a reason why the term “shutter angle” exists - film movie cameras did not use the same kind of shutter as stills cameras 🙂
I didn’t think it would be using the mechanical shutter, but it was the only thing I could think of that might be making a noise near the microphone.
maybe the OP can give us a better idea of what the noise is like? Maybe it’s some kind of electronic noise?
    • Do you know anything at all about photography, cameras, etc., or was this a purchase because of the trip? If this is your first entry into photography, ignore everything anyone tells you about settings, it will just confuse you. Put the camera in Auto and shoot, you'll be much happier.  Conversely, if you know about such things as shutter speed, apertures, ISO, Depth of Field, etc. etc., then you should already know that there is no such thing as a 'best setup' for an outing that will vary a widely as a safari. You will encounter everything from action to static shots, landscape, light, dark, the entire gamut. If it we me, I'd shoot in manual and make adjustments for each setting.  My wife and daughter went on Safari a year and a half ago. My daughter took her Nikon. My wife is not a camera person so I sent her out with a Kodak Easy Share 16MP something or other set on auto and told her to just press the button. We have several of her shots framed in 8 x 10.
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
