Imaging Edge App for two cameras?
I have two camera bodies - Alpha 1 and Alpha 7IV. And I want them both to connect automatically via Bluetooth (to my iPhone 13) so that the location data is being embedded on the photos no matter what camera I am shooting with:
1. Is that possible? If YES: How?
2. If not - any suggestions as how to implement a good solution (or compromise)?
Thanks for any input you might have!
