Soft case for A7 + FE 90mm Macro
Guest Des
Hello Forum,
I'm searching for a softcase that will provide a snug fit for the A7 mounted with the FE 90mm Macro. Can anyone provide a recommendation please?
Thanks,
Des
    • Hola, de un tamaño mas reducido que lo de aqui en España  Saludos Felipe  [url=https://flic.kr/p/2pQXGoV][img]https://live.staticflickr.com/65535/53718957065_012a904aaf_c.jpg[/img][/url][url=https://flic.kr/p/2pQXGoV]A7_08649nn[/url] by [url=https://www.flickr.com/photos/invierno123/]freme_3[/url], en Flickr
    • I have this lens and yes, it is normal if you shoot raw. Actually, what I discovered is that the lens is a little bit wider than 18 mm at the short end, and when shooting jpg, the image is slightly cropped, with still some residual distortion that I seldom correct, except for architectural pictures..  I totally agree with Pieter, the way lenses are designed has changed with the advent of digital cameras. In the old days of film, distortion, chromatic aberration and vignetting could not be corrected, especially when shooting slide film. This was not an issue with prime lenses, but was a major obstacle to zoom lenses development, up to the point tha magazines of the time warned against zoom lenses with more than 2-3X range.  Today lenses are designed as Pieter said, compromises are managed by software and this is even more evident in smartphones and compact cameras, which intentionally have no raw option.
    • For modern lens design, this is totally normal behaviour. To minimize size and weight of the lens and to improve many optical aspects, compromises are made in areas where the image can be corrected digitally. Distortion is one of these compromises: heavy barrel distortion is very common at the wide end of the focal range, up to a point where the corners of the sensor are not even covered by the projected image (i.e. rendered black). This is fixed by applying the proper distortion correction in your RAW editor: the black corners are stretched to a point beyond the image crop. Any leftover vignetting is then also digitally corrected. All this is done in-camera when processing a JPEG image, which is why it only shows up in RAW files. 2. Yes, these black corners are a property of the lens, not of the camera.
