A7r3 multi inerface stopped working with flash triggers
alexb
I've been using an Elinchrom Transmitter Pro flash trigger for some time with my A7r3. It's always worked flawlessly.
Yesterday when attaching it an error message appeared to say 'device not recognised' or similar. Since then I cannot get the trigger to activate the flash unit when on the camera.
I don't think it it's the trigger as it works off camera and on my A7s3. I also can't  get a Godox wireless trigger to work, which previously has.
I'm assuming a hardware issue with the interface or a firmware issue ?
Both camera and trigger are on the latest firmware versions.
Any help/advice would be appreciated.
