thanks!
@seb
It is one shot. Thanks!
@panitiduck
it's a 120mm dome(little smaller than 5" I guess) and made of glass yes.
It's similar to this one:
Thank you for reply.
I'm using 4.33" dome I find it's very difficult.
Where do you find this waterproof case?
Hi tomapaul,
I am Trung, I very like your picture, it's so amazing shoot. We are member of Sony alpha Group https://www.facebook.com/groups/sonynexvn/ and Fanpage https://www.facebook.com/official.sonyalphavietnam
If you don't mind, I would like to ask your permission to share your picture on Facebook. Of course, I will keep your name as the author.
Hope you ok with this. :)
