problem focus searching on eye detection A7S3
I am facing focus searching problems with my A7S3. When for instance using eye detection (locked on eye), the image keeps searching for a new focus point as soon as the head of the subject moves only slightly. As a a result the image keeps zooming in/out trying in finding a new focus point as can be seen in the video below. This is only a small section, I have interviews (filmed with a tripod) where it is 'searching' all of the time. Does anyone facing the same issues or may have a solution. The used lens is a sony FE 16-35 2.8 GM.
Though I can't believe it is a lens issue.
Greetings, Bob
