My LCD screen stopped working shortly after strange horizontal lines began appearing on the bottom on the screen. Need help!
Recently my LCD screen stopped working. Everything I’ve researched addresses the screen going black but my problem is a little bit different and I can’t find anything that addresses it.
 It started as a faint reddish-orange thin horizontal line right above the camera settings extending the entire width of the bottom of the screen. It was almost like a ghosting effect over the text. Over about the next hour or so the lines gradually multiplied upward in a variety of brighter colors until it was 1/2 way up the screen. Shortly after it fizzled the rest of the way up very quickly and turned dark. It didn’t turn completely black or even a solid just dark gray with thin vertical lines all the way across.
I’ve attached pictures of the screen when the problem got bad. It’s not a great pic but it was dark and foggy and I was in the middle of a huge field in the middle of nowhere.
The camera itself still functions properly but I can’t switch feed to the viewfinder because I had set it to monitor only. I hooked up an external LCD and tried to change it that way but the option was grayed out.
I have a theory on what could have caused the problem. I was doing some running around and quick on my feet stuff so I had worked up quite a sweat. I had my screen tilted up and on a few or more occasions my sweat dripped from my hat onto the screen several times.  I’m not talking about a mist either. I was sweating hard. Of course I wiped it off immediately but only the front. I was in a dark environment and trying to keep pace with my subjects. And honestly didn’t think it was anything to worry about.
In looking at the back of the LCD screen I noticed that it appears to be somewhat open in terms of the housing and If that’s the case my sweat could’ve easily rolled around the back into the grove that’s directly on the bottom on the back of the screen.
Im almost positive replacing the screen is the answer but before I dive into the repair I want to get some opinions
I did buy this camera refurbished from Amazon about 6 months ago and also purchased a warranty with Asurion but I’m not paying deductibles and waiting forever to solve this over a $50 part I can replace myself. If it was serious damage then obviously I’d have no choice.
I would greatly appreciate any feedback!
Welcome and good luck :)
You seem settled to it being a hardware problem and probably permanent. Good luck too, with the part only costing $50! But I don't have the experience. Youtube probably has the disassembly/reassembly covered.
(If it's hunchtime, I'd agree about the moisture. I've heard of over-wet computer-monitor cleaning causing this kind of failure. On the other hand... any chance the ribbon cable simply came loose?)
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
