Congrats on the camera. Current promos make it a super value.
I don't know anything about Nikon software but perhaps these are what you're looking for ImagingEdge and PlayMemories Home.
I don't know of anyone that likes these apps but they are available. I use Capture One and there's a free version of that for Sony, iirc.
Edited by thefsb
Thanks much. Just got back from being out all day. Playing with my new toy.:)
I will try what you have suggested and will eventually get there.
Regards,
Norman Silva.
Edited by Norman
Changed name to first name
