Lens slighly clicks and moving on body when locked (A68)
Hi guys,
I just got on a deal new Sony Alpha 68 - not the top in the class, but good value for the money ($450). Not payed yet with the camera (the battery is yet charging), but I noticed that when lens (the kit lens) is attached to the body, it can be slightly moved by hand  - not totally locked, as it should. I haven't had this problem with my previous A55. Is that common? It can be somehow annoying...
Regards!
