Milky Way from Boeing 777
  • Please log in to reply
5 replies to this topic
#1 mttdxb
mttdxb
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 16 February 2017 - 03:02 PM
Advertisement (Gone after free registration)
13 exposures taken from a Boeing 777 over the UK last August with A7R2 and 28mm F2.0.
https://www.flickr.c...57673885069811/
  • Moody and Ben like this
#2 TravelForPictures
TravelForPictures
    Advanced Member
  • Members
  • PipPipPip
  • 33 posts
Posted 16 February 2017 - 06:27 PM
Wow!That is so cool!!
Body: Sony A6000
Lenses: Sony: 10-18mm F4, 16-50mm Kit, 16-70mm F4, 55-210 // Rokinon: 12mm F2.0 // Sigma: 30mm F2.8
My Pictures:  http://www.instagram...avelforpictures
#3 mttdxb
mttdxb
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 16 February 2017 - 06:46 PM
in case someone wants to try this, a few tips & tricks... took quite a few attempts to get to this one
- biggest problem are the reflections in the aircraft windows.
- A380 is absolutely bad, the double glass is 5cm apart and the 2nd glass is reflecting badly
- 777 is a lot better, the glass is just 1cm apart and has very little reflection
- make sure you are not sitting above the wing (obvious i guess)
- make sure you are checking the milky way position of the flight path in Stellarium and then decide which side of the plane to sit
- take a dark cardboard that covers as much of the aircraft window as possible and cut a hole into the centre for the lens to go through (alternatively the backside cover of your inflight magazine will do the job ;-))
- use a lens hood and press it against the aircraft window to fix the camera position
- use manual focus, once focus is OK and exposure is acceptable, take a series of pictures (20-30 at least) without moving the lens.
- exposures between 0,4 and 0,8 seconds seem to be the max that works unless you are flying in really smooth air
- process in DeepSkyStacker or manual alignment.
good luck...
  • Ben likes this
#4 Wanderer
Wanderer
    Advanced Member
  • Members
  • PipPipPip
  • 153 posts
  • LocationColombia
Posted 17 February 2017 - 12:03 AM
Good info. Was wondering about shots through a plane window. However wonder what the seat mate or stewardess thinks of the window shenanigans in these troubled times when you pull out your sheet of cardboard with a hole cut in it.
#5 KMG
KMG
    Advanced Member
  • Members
  • PipPipPip
  • 85 posts
  • LocationOttawa, Canada
Posted 17 February 2017 - 01:29 AM
Beautiful shot!
Thank you for the detailed info regarding how you got it mttdxb. My first thought after taking the image in was how did they pull it off.
Congratulations,
KMG
#6 mttdxb
mttdxb
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 17 February 2017 - 01:27 PM
I think the paranoia is something that is US specific ;-) usually people are quite excited and ask for a copy of the final picture ...
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
x
New Members Welcome!
Not yet registered? Really?
Registration is free and takes only a few minutes.
After the free registration you can discuss with members from all over the world, put questions and present your images.
We are looking forward to you!
Admin Andreas und Sony Alpha Forum Team
Register now! X
