Need some opinions!
Nick
I currently shoot with the A7r, primarily landscapes and some portraits.  I currently own:
14mm Rokinon
35mm Zeiss
85mm Rokinon
I'm headed to Argentina soon and feel like there will be some occasions where I will wish I had a longer zoom.  I'm about tapped for cash after picking up all of the above so I started looking at legacy glass.  Here is what I have my eye on:
Minolta MC Tele Rokkor-QF 1:3.5 200mm manual lens
adapter
http://www.amazon.com/gp/product/B00870NQRO?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=AAWX4OXQA15SW
How is this glass?  From what I've read it seems pretty good.  Anything else I should be looking at?
Thanks!
While I have not used this particular Rokkor I have used many shorter Rokkor primes. Old Minolta lenses are very special so I would assume this lens would perform at least in an acceptable manner, I doubt it would be a dog. But again I have never used one in the wild.
I can recommend another 200mm, the Konica Hexaon AR 200/4. I have been pleasantly surprised by my copy. The lens is more then sharp enough and has some pleasing rendering. And Konica adapters can be had for pretty cheap and have the benefit of being the shortest adapters of all the old Japanese SLR lenses. In other words they have the shortest flange to focal distance before you get into Rangefinder glass. Keep in mind if you ever get this lens, it is a HEXANON 200/4. There was a later HEXAR 200/4 that wasn't quite as good, at least the old lens reviews would have you believe. Here are some examples of my copy all shot on my a7.
The good one in the Minolta MC / MD lineup is not the f/3.5 but the f/4.
It is as good as the f/2.8 version from tests I've seen around, only 1 stop slower.
I've pitted mine against my Leica R 180/4 and the Leica wins up to f5.6, the Minolta from f/8 onward so I'd call it a draw.
http://www.ebay.com/itm/Minolta-MD-Tele-ROKKOR-X-200mm-F4-lens-/221957374345?hash=item33adb0c189:g:Fm8AAOSwc0FUpIRY
That's a pretty beat up lens, but something like that?  Are the Celtic versions ok or no?
The f/4 versions are to my knowledge all the same optically, so yes one like this one or even an MC version like mine (aesthetically similar, just "MC" instead of "MD" on the filter ring).
The Celtic are different lenses, of far far inferior quality. Once (30 years ago) they were much cheaper than the Minolta equivalent so buying one might have been justified, but nowadays they basically command the same price so you don't have a single reason not to go with original Minolta glass.
I see a ton of F4.5 versions on ebay, but very few F4.  I assume those are not the same lenses, correct?
