I've tried all the flash modes, leaving it on regular (fill flash), M exposure mode, 1/125 second. I've tried to different shoe to PC adapters, checked position of contacts, tried two different cords into my Dynalite pack. Tested the cords with my meter, they fired. I tried my tiny Godox 350 flash in the camera shoe, it fires. Is there a setting to enable external flash I am overlooking (I saw disable flash as an option, not selectable in M mode.) I'm shooting still lifes with a custom bellows (no electrical contacts through the lens mount), thought that might have something to do with it, but it doesn't fire with a regular Sony lens either. Any suggestions (besides using a radio slave, which I don't have available right now)?
Optical slave the studio lights
to your tiny hot shoe flash. If
this approach creates a stray
light problem, block the stray
light but avoid any small box
or any sort of wrap that heats
up the tiny flash.
Most optical slaves are using
basically near-IR wavelengths
so you can also use deep red
gels to limit stray light.
Sometimes flash has being playing up on my Sony cameras, despite settings being correct. In those cases, a camera reset has fixed the problem. Could be worth trying.
