Dear fellows
Today I tried an old m42 lens 300mm on my A6000.
I have 2 adapter for this: one short really slim and another one quite thick.
I didn't manage to reach the focus. It's out of the range with both. Neither with a subject at infinity.
Did anybody tried?
Some idea why?
It's so strange.
I used with the same lens a canon 6d FF and worked great.
any suggestions?
I suspect the adapters aren't normal M42 adapters.
Even a poorly toleranced adapter will ALMOST get
infinity focus. The longer the FL, the less any small
flange distance errors will mean. So with a 300 that
doesn't quite reach inf focus a 20mm lens would be
unable to focus beyond a few feet. A gross error at
300mm is NOT due to an out-of-tolerance adapter.
Do you measure approx 45mm from the front face
of the adapter from the focal plane of the body ? If
so, I wonder if the stop-down flange in the adapter
is the problem. If the iris actuator pin on the lens is
jammed, such a flange [that is normally beneficial
and necessary] could block the lens from seating
to full depth in the adapter.
https://en.wikipedia.org/wiki/Flange_focal_distance
BTW, does one of the adapters have glass in it ? If
so, it may be calibrated for wide-to-normal FL, and
lengthens the effective FL of the 300 way too much.
Other long shot possibility is you've found a 42x0.75
adapter for E-mount. Not only will it have too short a
flange distance, but an M42 lens will only thread into
it a few turns before it binds up. This would explain
the adapter you say is rather short.
I'm rather curious how you acquired these. The M42
adapters on the market are overwhelmingly normal
ones. To bag TWO odd ducks is kinda unthinkable ?
Not sure if it's even possible but maybe the reverse
of the above is going on. If the 300mm is a camera
maker's brand, then this last thought does not apply
I'm wondering if you do not have an M42 lens in the
first place. IOW you put a T-mount [aka T2] lens on
the Canon via a normal T2 adapter [42x0.75 thread]
and now you're jamming the lens's T2 thread into a
couple of [normal] M42-to-Canon adapters. Flange
depth for a T2 lens [without installing a T2 mount or
adapter] is 55mm. So ......
If the adapter that puts that 300mm onto your Canon
body is about 11mm thick, you DO have a 300mm T2
lens. Any normal M42 to Canon adapter is only about
1.5mm thick.
If the adapter for the Canon is about 11mm deep then
nothing is out of tolerance, but you do have incorrect
hardware. If the "M42-to-Canon" adapters are normal,
then you just need a T2 mount for the rear of the T2
lens. Alternatively, you'd leave the Canon adapter on
the 300mm and just get a "dumb" adapter for Canon
lenses to Sony E-mount bodies. Someone may try to
"upgrade" you to a "smart " adapter. It's useful if you
wanna use real Canon EF lenses on the Sony, but is
of zero benefit with M42 and/or T2 lenses, cuz those
have no electronics in them.
Below, the thin adapter is M42 to Canon. The thick
one is a T2 mount adapters for T2 onto Canon.
Guessing here. It sounds like one adapter is a M42 to Canon adapter and the second is a Canon to Sony adapter.That would mean you don't get the correct distance between the sensor and the lens. If that is the case, it will work if you just buy one M42 to Sony adapter instead.
If there is a T2 adapter involved, I don't know because I avoid those.
Dear fellows
Did anybody tried?
Some idea why?
It's so strange.
Dear
you are so kind to reply me so deeply!
I take time to study all the things you wrote me. First I can already say that there is no glass in the adaptator, they are chinese rings just metal really simply and one is short and the other is the standard height for the nex e mount. Np problem for the thread becaus it screws and that's all, so no worry about T2\m42x1 or x2 questions. It is a matter of focal millimeters.
I'll come to you with the mesures!
Ok so
Here I 'm with the corect mesures:
With the short M42 I have 38mm from the last lens in the back of the tele 300.
With the long M42 I have 78mm from the last lens in the back of the tele 300.
With both I cannot reach focus. Doesn't matter the size fo the screw (m42x1 or x2) it fits till the end with both.
Measurement to a piece of glass has no meaning.
The flange faces are the flat circular surfaces that
meet when a lens is mounted. One flange is is on
the lens, the other is on the body. When reporting
a "flange distance" you don't even need to have a
lens on hand.
The flange distance for M42 is about 44mm and
you must measure this from the flange face on the
M42 mount [at the front of the adapter] to the focal
plane [same as sensor location plane]. The focal
plane is marked on the body by a circle with a line
crossing through it. It's a very small symbol and is
on the top cover of the camera.
I cannot read the notes on your papers. The photo
is very unclear.
Also I discovers that the last part can be unscrewed
I won't repeat all I wrote in post number 3, but that
is where the answer exists.
Referring back to post #3, I warned you about the
existence of 2 different 42mm threads, the T-2 and
the M42. The lens with the removable end is a T-2
lens. Look up [Google] "T-mount photo lens". Try
Wikipedia in particular.
You say that all your 42mm threads thread nicely
and do not bind up before seating fully. Normally if
you mix a T-2 with an M42 it's typical to get a poor
fit that won't thread all the way in. But with sloppy
manufacturing tolerances combined with soft metal
such as aluminum, occasionally a mismatch WILL
thread all the way together. I suspect that is what
you are encountering.
You seem to have at least one T-2 lens. You also
have an M42 adapter. What you've called "screw
unknown" is an assembly connection not intended
for routine removal. It does allow for removing, or
reversing, of the tripod collar, which is supposed
to be included with such lenses. What you labeled
"M42 short" looks like an M42 T-2 mount wearing
an M42 to Canon adapter.
For any further info, go back to Post #3. Be sure
you do not confuse your removable M42 mount
for the T-2 lens with any other M42 devices, such
as adapters for M42 lenses onto Sony or Canon.
If you haven't yet read this, read it:
https://en.wikipedia.org/wiki/Flange_focal_distance#cite_note-ikegami.com-2
 I have not checked it for errors, but overall it will
give you understanding of flange distance.
yes its the same that I have. Simply identical
Moreover this m42 ring works with other lenses!
Ok so the mesures of the two M42 rings are:
42mm for the big (the above photo)
5mm for the short one
Flange face to flange face, any Sony to M42
adapter must measure 27.46mm in length.
If you are measuring the front flange face to
focal plane distance of an M42 adapter when
installed on a Sony, that should be 45.46mm.
Did this M42 telephoto lens focus properly
when adapted to a Canon ?
This thread is moving in circles. I would suggest a quick online search for "flange distance Sony". That will throw up multiple sources that answer all questions.
    • I am considering purchasing the Luminar editing program for IOS to use with my A7iv; however in listing which cameras are compatible, there is this statement: "Sony vcb cropped p send-raw format is not currently supported."  Does anyone know if this means that the program will not work with raw photos?  Has anyone successfully used this program editing raw photos?
