I'm new to this list. A search brought up none of my key words, so sorry if I missed a relevant thread. Here goes: I bought the A7II to get as much of a fully manual SLR feel and control as possible. I've since purchased a mix of AI and AIS lenses. I'm simply looking for tips, tutorials and recommendations to better my skills and photos.
The only specific for this post is: are there any adapters out there that aren't ~3cm long? the length of the adapter creates weight by its cantilever.
Best,  -Josh
Best,  -Josh
Okaaay you definitely do need a tutorial, but you
are getting waaaay ahead of yourself in seeking
a tutorial for using AI lenses. Start with a tutorial
on the basics of why gear is the way it is ... real
basic. Your question is kinda like, "Can I get any
ice that won't melt on a hot day ?" No doubt thaz
a seemingly desirable trait, but ... well ... I gotta
believe you would never actually ask that. Get
tuted on the basics and you won't ever ask if all
adapters hafta add 3cm. It's not rocket science,
so it will be an easy read, and will open up many
useful concept that help you get the most out of
your gear ... And you'll be getting that due to a
grasp of essentials, rather than simply learning
various procedures and settings devised to yield
known results. IOW, basic understanding means
less need to memorize procedures ... which will
make things much simpler.
Sorry, but I have no idea of any specific tutorials
to suggest. Asking for a referral about that might
be your next logical question to post :-)
I fully expect that the "Basics Tutorial" will also
answer your original question, AND will serve as
your "Using Adapted AI Lenses" tutorial as well,
cuz using adapted AI lenses really is simply an
exercise in applying the basics. Yup, your idea
that an a7-II plus some AI lenses offers a close
approximation of a fully manual SLR is right on.
That has been my kit for a coupla years and I've
been doing this for a coupla generations. It's a
very fine "Essentials Kit" ... which is all I need :-)
This recent Article on philipreeve.net might hold some insights that could help you.
https://phillipreeve.net/blog/adapters-manual-lenses-sony-a7-series-guide/
In regard to the length of the adapter the following illustration from the article is most comprehensive why these adapters not only need to make a physical connection of different bayonet standards but must also maintain the proper distance to the projection plane. If the adapter is too long, you lose the ability to focus on a target at infinity and if it is to short, you decrease the close focus ability. Both errors push the lens in directions for which it hasn't been designed/optimized for.
Practice. Shooting with manual lenses takes practice. Focusing needs to be second nature so you have to work it into your muscle memory. Start with simple, static scenes to get to the point where you can reliably focus the lens and work the camera settings without reflecting on it. Then move on to moving subjects and continue practicing.
At the same time get a book that teaches basic image processing techniques. If you're using Lightroom or Photoshop, try Scott Kelby. His chirpy prose is an acquired taste, but his techniques are solid and easy to learn.
