Did you try amazon.com, look for lens accessories/lens adapters and converters. They screw onto the filter thread at the front of the lens, you just need to find one with the magnification (less than 1 for wider) that has a screw thread that matches your zoom lens, which I think is 55mm.
Thanks, but the generic ones have major distortion and color aberration. I'm needing something close to professional quality. Sony has these for some lenses.
