I'm ditching my heavy DSLRs for rangefinder mode cameras like Sony A6500.  Although I'm mostly into still photos, I have a good knowledge how to produce videos that can now be taken quite well in still cameras.  I've been doing extensive research on this camera in youtube videos pros and cons.  I've been also to review sites about A6500.  I'll be using this for travel and festival events as main and backup.  Sony A6500 fits my preference as a light camera that you can take anywhere and anytime.
    • I do a bit of astro photography and do a lot of research etc. on best settings to use. I have never heard of anyone using ISO bracketing! Typically, higher ISO settings such as 1600, 3200 or 6400 are used and multiple light and dark frames are stacked to reduce noise. If you are worried about noise in dark foreground areas then just use a seperate exposure for them then blend the exposures in post processing. By the way, I also have an A7R5.
    • I would try resetting the camera. I can’t really think of anything else you can do other than try a different card.
