I have a a6000 and the Minolta 3600hs flash. I also have the hot shoe adapter to it will work on the camera. I have been on a couple portrait shoots since getting the adapter. My problem is it seems like the TTL doesn't always work. Every time I use the camera the mode on the back just says on not auto. I used to be a canon shooter then moved to mirorless for the size. I used hot shoe flashes a lot on those dslrs with no issues. Even when I change the flash compensation in the camera settings nothing seems to change.
