Hi,
yesterday I noticed for the first time a red dot in the middle left on the black screen in the EVF and the rear LCD screen on my A7RII, when I closed the lens with the cap. When I opened the lens, the red dot disappeared.
It doesn't seems to be a pixel failure, because it is appears in both EVF and LCD screen. I updated the latest software version 3.20 without having any impact on the screens.
Any ideas what the reason could be?
Thanks in advance
Joghivan
If it's in BOTH viewing devices then it IS a pixel problem.
Frames of scenes where a somewhat dark portion of the
subject occupies the location of the red dot should also
exhibit the dot, on careful inspection. Most likely it would
show worse in high ISO exposures. Moderate ISO and
bright sections of a scene will tend to mask the problem.
The fix for this in Canon SLRs is well known, as Canons
re-map pixels during the manual cleaning function. Sonys
don't need the same type of manual cleaning function as
do SLRs.
There is some sort of "sensor lock" on a Sony to aid with
manual cleaning of the shifting sensor in Mark-II bodies.
I've never used that, never had hot pixels in a Sony, and I
don't know if it's what triggers re-mapping of pixels, but it
seems worth your while to research that.
Hot pixels tend to come back after a while, in exactly
the same place, cuz they are actually a "not-quite-flaw"
in the sensor itself. Long exposures and/or high ISO
shooting tend to re-provoke them.
A thing I learned about re-mapping when researching
for my Canon is something that is probably common
across all brands. The re-mapping action sees only
the more obvious hot pixels. You can make more of
your potential hot pixel sensor "flaws" bloom into the
"more obvious" category so that the re-mapping is as
through and as long lasting as possible.
You do everything you can to provoke all "flaws" to
"bloom" into visible hot pixels by:
Heating up the sensor by running it at least 10 to 20
minutes [set your power saver mode to 30 minutes].
Do this at maximum ISO. Then put on the lens cap
and shoot a dark frame at several seconds duration.
If you chimp that dark frame you should see more
hot pixels than you ever expected.
At this point, with the hot pixels maximally provoked,
do the re-mapping [date-time function with Sonys or
manual sensor clean function with Canons].
  • 11 months later...
Just noticed the same thing yesterday on my A7rii and noticed that if I switch my AF on my lens off to MF the red dot changes to a red dash. I only see the dot in a low light situation.
Could this simply be an indication for AF vs MF?
What does it say about AF/MF indicators in the [RTF] Manual ?
