I have been using Sony a6000 for a month or so now, and I have used it on a paid gig (3 days long) for some shots, and it worked great. Today, while shooting I changed the frame rate from 60fps to 24fps, and immediately after that I started to notice that the screen showed terribly darker. As soon as I started recording video though, the exposure changed and the footage became very bright. I played the recorded footage back on the camera and it showed what I was seeing while recording. However, anytime I stopped recording, the screen showed much darker exposure.
This had never happened before. I tried googling on my phone but couldn't figure out, which setting I had accidentally changed.
Then, I wanted to look at the histogram to see what to believe. I swear I have seen the histogram before on a6000, but in this case, I couldn't see the histogram either. I tried flipping through the menus, or display button (wheel, up) but I couldn't get the histogram to show.
One other weird thing, if I popped up the flash, the non-recording screen was as bright as while recording screen. I went through bunch of settings on my camera and they all looked good.
So my question is:
1) What setting is causing my screen while not recording to be really dark, and not give the right exposure?
2) Where do I turn on the damn histogram?
Much thanks.
Image effect preview in the live view menu.
The flash thing makes sense. If you're in
effect preview viewing mode, and using
flash, you apertures tend to be too small
for viewing by ambient illumination, so the
pop-up flash cancels the effect preview
when the flash is engaged.
Seemingly weird behavior of LCD viewing
briteness will differ depending on manual
or auto exposure mode. You could be in
effect preview and never know it if you're
always in AE, cuz you never see the effect
preview of over or under exposure ... altho
you WOULD see the effect, in AE, of any
"+/-" exposure biasing.
Histogram, if enabled, is on the "display"
button ... not a real button, just the top of
the quick control wheel.
I am sorry, I can't find a menu setting for "Image Effect Preview". I only see "Live View Display" under cog wheel, tab 2, and it has options for "Setting Effect ON" or "Setting Effect OFF". Presently it is ON.
So what do I change again?
Sorry. Different marques use different words for
the same thing. "Setting Effect" is where you go
for addressing this.
You say it's presently "ON". Just reread the post
above realizing that what I said about the "Image
Effect Preview" applies, even tho Sony calls it
"Setting Effect". Everything in the above post is
accurate except for the NAME of the feature [you
will notice that both are about EFFECT].
  • 1 year later...
Note that when selecting effects or filters to apply to your clip, you might be inclined to use the Brightness and Contrast filter. I never use this filter because it affects too much of the image. This filter is like a simple “tone” control that turns clockwise for treble and counterclockwise for bass. The Color Curves, Levels, and other color grading filters are more like a graphic or parametric equalizer, giving you much more control.
If your footage is overexposed or too blown out, that is a different problem. Once footage is truly blown out, then detail is lost and you can’t get it back. When shooting, it’s better to underexpose just a little than to risk true overexposure. (Test the limits of your camera; on our older VX-2000, I can be in the zebras at 100% and still pull out some detail, but we have not been so lucky with newer HDV cams.)
For more tips refer to Sony A6000 Manual.
    • This is just a quick and dirty first try composite from my efforts the other night attempting to capture the Full Lunar Eclipse. I will refine this and do a version with a foreground over the next week or so. The weather reports weren't good, as far as cloud cover went, so I was thinking I may not bother with it. The afternoon ended up being sunny and warmish with only the odd cloud here and there. I got my gear ready just in case. Sunset was just before 6:30 and after that I was checking the sky every half hour. Just around midnight I decided I would give it a go so I made some coffee and some sandwiches and headed off. So anyway, long story short, I had to brave the cold, the wind, a heavy dew, sea spray (the sea was quite rough and the tide was coming in fast) and quite a bit of cloud just after the full eclipse. Anyway, I'm pretty happy with this first attempt.
    • I'm going for it. Yeah, it's a superzoom that has all the typical traits of a superzoom, but that 20mm short end is too good to pass up. This lens has been rumored for a couple of years; I can't wait to get my hands on it. If it's any good I'll sell my 24-105, I don't need a fast lens for the planned use.
    • Help! I am leaving for a safari in a few days and need help setting up my Sony a6000 for the best wildlife shots. I also have a Tamron 70-300 lens. I'd really appreciate any suggestions for the best settings. Thanks in advance.
