Hi,
i have a slight problem with my A6000 camera. When I put it to manual focus mode in total manual mode (M) it still seems as something is going on behind the scene.
I tried to do some close timelapse of flowers, but the frames are not the same - there are different in size. The difference is minimal - few pixels in zoom dimension - but it is quite annoying because than there is like flickering in my timelapse. Is there any other setting that i need to disable? I'm using kit lense 16-50mm...
Thanks.
