Hi all,
I am considering a power zoom lens for my Sony A6000.
My question is, can the zoom be controlled using the remote control (through the multi-usb port)? Or can it only be controlled on the lens itself?
Cheers
Dominic
PS. An example of the lens I mean is this http://www.sony.com.au/electronics/camera-lenses/selp18200 or this http://www.sony.com.au/electronics/camera-lenses/selp1650
YES! Sony's remote cable attached to the multi-port will control video start/stop and zooming of lenses with the power zoom (PZ) capability.
