I am in the middle of transitioning from Nikon to Sony a7rii.
Does anyone have experience comparing the native f4 lens versus adapting the Sony A-mount lens?     I have read that the f4 is certainly not small ( just as big as the 70-200 f2.8 Nikon that I'm "downsizing" from) and softer at the 200mm range.
I am hoping to find a lens that is optimal for low light theatriccal performance. shots.   I would also consider shooting a 135/2, crop mode if necessary for reach.
Size, price, and image quality are main values here.
The Sony is 72mm (against 77), 175mm long (against 215 + mount size) and 840g (against 1500g). Its big, but also compact, very easy to handle.
I assume you mean this Nikon http://www.bhphotovideo.com/c/product/644741-USA/Nikon_2185_AF_S_Nikkor_70_200mm_f_2_8G.html
I used the Sony at an indoor hockey game, its probably similar to theater lighting levels, and I had to turn the ISO up. This is on an A7ii, 141mm, ISO6400, F4 and 1/2000s, from the mid rows of a grand stand. I think its OK actually, a bit grainy, would prefer ISO1600.
Yes, that's the comparison I'm thinking of.  And yes, I suspect the light levels will be similar.   As I will be using the a7rii, I should be able to dial the ISO up a little more and get away with it.
Thanks for posting the picture, too.
I catch myself, that I enjoy using my Sony G 70-200 f/4 a lot on my A6000 with battery grip, and with an range of 105-300mm, mostly with 300mm and excellent results!
