Hiya,
Sorry, does anyone have working links to older versions of the Riii firmware (for Mac)? It seems 3.10 is the only one left on the site? Someone on another forum said it's possible to downgrade the version if you rename certain files within the package - like naming things 3.11 or something? It's prob just my imagination, but feel like the colours got a little duller since I upgraded to 3.10, so naively hoping I might be able to figure out a way to return to an earlier version, ideally 1.00/1.10. Or if there are any super legends who've achieved this successfully and have a link to the firmware file they created, that'd be amazing.
Thanks so much.
