1 hour ago, Tony Pullen said:
Recently updated imaging desktop and unable to use now as my Mac is too old.....
Is there a version available for Mac OS Catalina as I love the software but can't afford to buy an up to date iMac
Many thanks
Seems too be just the viewer part that I can't use
