Hi everyone! I have a few questions about using the AF tracking on the A7c.
1.Anyone know how I can get the AF point (white rectangle) to shiw up on screen when set to AF Single Shot (not Servo)?
2. How do I set the AF point to lock on a subject for tracking by pressing the shutter release button halfway instead of always using the rear AF button all the time?
In other words, I'd like for the AF point to be visible on the LCD and/or EVF at all times, and I'd like to use it to lock on to whatever I choose for tracking that spot.
Right now my A7c is set up (most likely by mistake on my part) where tge camera selwcrs the AF point and tracks whatever it wants, not what I select.
    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
