Hi I will soon be buying a Sony A 7 Sii I shoot realestate videos for YouTube. What I want to know is which lense should I get first. I am on a budget so a wide frame lense is a must. Stills are not important. Would a Sigma equivalent be just as good as they seem a lot cheaper. I use a Ronin S gimbal if that matters. Thanks in advance.
You should check out the 17-35mm/19-35mm/20-40mm zooms.  They should cover most interiors well.  Your biggest problem will be lighting -- too low (which means a HIGH ISO) or too much contrast (which means contrast control).
Edited by XKAES
